Hey guys! Looking to make my ideal road racing daily. Before we start i should probably mention i live in la so i know smog woildnt look to kindly on this but the upside is I'm a mechanic and went to school for it so if the mods dont require a lift I can do put the parts back on myself when the smog man needs me to. Just uh, dont tell anyone ya?
Anyways ill be doing a lot of these mods through out the year and have a good idea of what to do but kind of at a speedbump when it comes to getting to exactly where id like to be.
ideally id like to get the car to have 260hp flywheel and weigh 25-2600lbs, heres what i have in mind so far:
Power
*m50b25 intake
*s52 cams
*ecu flash or chip
I hear that should get me around 220-230hp
Weight
*seats -100lbs (stock seats i think are 70-75lbs each? Was going to go with sparcos at 23lbs each)
*battery -20lbs
*Spare + tools + carpets -40lbs?
roughly 160lbs so probably puts me at 2750?
Anyone know if you save weight if you ditch the soft top and go for a hardtop? Any suggestions not thought of here that'd make the car still semi drivable? Id like to keep the ac until I get a second car because I live in desert land =p
Also was thinking of switching to an electronic fan and electronic water pump to free up some power. The weight is whats killing me unless i go full race car.
Power
*m50b25 intake
*s52 cams
*ecu flash or chip
Weight
*battery -20lbs
