Help!!!!
Mazza
Bognor Regis
The only bit I need on the old roof is the micro switch ….
on one end is a micro switch , on the other is a white 3 way connector…. and the wire goes through the frame:arghh::arghh::arghh: How the f…do you get it out and then reinstall it back on the other roof ????
Please reply to Old Bognorian@getting really annoyed , com =))=))=))=))
Bampz
Pembrokeshire
Mazza , if you take the micro switch out of the holder I think you can detach the wires and feed it back through the frame , mind it was a couple of years ago when I changed mine and I'm a bit older now
AntStark
Hampshire
2002 3.0 Sport
The pins should pull out of the white connector..or you can use cable cutters and a soldering iron 😁
And shrink tube . . . . .
AntStark
Hampshire
2002 3.0 Sport
I would seriously consider changing the wire Malc.. it’s known to split
