Guys I have a guy that will do my VANOS seals, I have read that my 2.0 could be single or duel VANOS, I have also read that the facelift is duel, is there a spec sheet that I can check, thanks
Excellent, thanks, so simple when you know2.0 litre are all double vanos Sean. They were only available from1999 - 2000 as a face-lift model, engine is M52TUB20.
No problem Sean, happy to help. Basically the same engine is in the 2.5 (for the US market) and 2.8 from Sept 98 onwards. I did read somewhere that the 2l can be converted to 2.5l by fitting a different crank / con rod configuration.Excellent, thanks, so simple when you know![]()
