Hi, I am fixing the oil leak from the oil filter housing where it bolts onto the block. Does anyone know what the torque settings should be for the 6 bolts? I can't seem to find that information anywhere. Thanks.
Cooper
Cooper
Mine was the same when I changed it earlier this year. I tried to find you the actual torque setting in the TIS last night but found everything but................ It was so brittle I couldn't get it out in less than 5 pieces! It was rock solid, no wonder why it was leaking. .....
It sits in the circular hole at the top of the filter housing - see second pic MAKE SURE YOU PUT IT BACK IN THE RIGHT WAY ROUND!Thanks. Where is the nvr bush located. I have not seen it.
Oops - sorry missed that - still half asleep.Thanks. You have a four cylinder? Mine is the six and is different. There seems to be a small valve thing in the middle of my housing.
