S54addict
- Joined
- Jan 20, 2016
- Points
- 95
- Model of Z
- S54 Z3M, Z4M coupe/roadster
what an amaizing day for a drive! Well, until I stopped for a sneaky 1/2.... Jumped back in the Z4M flicked the key only to hear a click tried again a short turn over maybe once but not enough to fire repeatedly tried about 10-15 times and a mixture of clicks or tries then just I was giving up hope she turns over and fires up as if nothing had happened??? When I got home I turned her off and checked the battery terminals ( as I disconnect over the winter ) seem fine tried starting and basically a repeat of earlier, again resulting in a start as if nothing was wrong.
Is this the start of the starter motor failing, or solenoid, or possibly ignition switch??
Any help appreciated
