Help me remove this knob!
T-Z3
Hi all so I’m struggling to get this gear knob of of my z3. Watched a YouTube vid and people just seem to put it off have tried with mine but the thing won’t budge am I missing something is there a special technique!?
Best with the roof down, two hands and give it the mother of all yanks. Mind you don't punch yourself in the face.
Edit: If that doesn't work a previous owner may have glued it on ....... hacksaw.
Can't beat a good knob thread ............... ;)
He used to be in the WWE, "Hacksaw" Jim Duggan. !!
ps. A cordless angle grinder could be the way to go.
Paul Rice
Doncaster
Z4 2.5
I had the same problem on my Z3. Ended up using a Hacksaw.
Where abouts did you cut ?
The missing information is that you have to destroy the gear knob by cutting it to bits. No particular technique or approach, just start cutting till its no longer attached.
It’s on a metal shaft so you’re unlikely to cause any damage to anything other than the knob!
Paul Rice
Doncaster
Z4 2.5
As Gary says, its a demolition job. First i cut the outer skin which left the plastic that fastens to the stick then i used a hack saw and cut a slit down one side of the plastic then it just peeled off. Good news is when i came to strip the car the Msport (fake) knob came off OK top down quick snatch and it came off. What made it easier was the seats had been removed so i good kneel in the car and get good purchase
Z Victor 1
Formerly "Ontiken1"
Ripley,Derbyshire.
E 89 Z4 S drive 23i
Agree with Mike, I got the one off my Z3 by standing, with the roof down of course, on the seats and pulling like mad. When it did come off it hit my gut and I fell backwards thinking wow, that was very close to the wedding tackle!:eek:
Mike Fishwick
French Zeds
Daglan, France
You do not need to cut it off, or use a brute force pull - even though Bentley specifies a 110 pound pull.
I find that tilting the knob to one side while pulling normally works after a few failed attempts.
My wife used to sometimes remove the knob while changing gear - but she was not limp-wristed!
