HELP DAMP PASSENGER FLOOR only in a small area?
bruce&kim
not sure how much use I will be but happy to have a look at the weekend ...only in Torquay but busy till saturday
laurence
Plymouth
i might come down past you if thats ok? I'm taking the Zed up to yeovil saturday to see my Dad with his Triumph Stag *with the Non rover V8*
bruce&kim
sure we can sort something out just pmed you my number..
Aceman
Moderator
Wakefield
///M Roadster
Just reading this and I think you are already looking in the right areas. The hole in the seal that Gary has pointed out to you is by far the most common cause of leaks as it allows water to flow down inside the seal into the footwell. I think if your windscreen was leaking it would be as a result of a poorly installed replacement screen so if you can see evidence it is not oem them that could be a possibility. Other than that it is just a case of trial and error until you locate the source.
laurence
Plymouth
the silicone has been tidied up since these pictures as it does not do it any justice! I'm hoping this will have sorted it!
bruce&kim
Well done fingers crossed have you tried the hose pipe test? if it still leaks at least you would know where from ps I hope you never used to work in submarines :eek:
laurence
Plymouth
haha in the process of it now, no never worked on subs joining my next ship in Dec :)
