I need your help. I just bought my first BMW, it's a 1997 Z3 1.9 automatic with 155k miles. Purchased condition is "NOT RUNNING".
I reviewed the factory service manual, the electrical manual, and searched and searched, but I can't figure out why the car doesn't start.
SYMPTOM: Crank but no start
CHECKED: Fuel pump relay (underdash) GOOD
CHECKED: DME main relay (engine bay, by passenger firewall) GOOD
CHECKED: Brandnew FRESH BATTERY installed GOOD
CHECKED: Fuel pump with jumper (pin 87 and 30) pump does run GOOD
CHECKED: Fuses are good (fuse 13 and 18 engine bay fuse box) GOOD
Note: But I don't hear the pump with relays in place and the key is turned. Also, gas gauge is not working, but I think I did see it showed halftank when I jumped pin 87 and 30.
If both relays are good, why doesn't the fuel pump prime?
Please help!
Thanks,
Please help!
Thanks,
