sorry Sean, they are just beige electric ordinary ones.
Sir P
Sir P
I have a '96 1.9 L Z3. American. Is there anything I can check on my system that would help you? On the '96, I have no locking key fob. I must use the key to physically open the car. However, the wiring might tell you something. FrankieHelp please
I have just attempted to fit an aftermarket remote control locking system fro United Auto Security (BMWRSZ2-RH)
The kit is very simple and connect to the middle plug of the ZKE behind the glove box. There are only 4 connections that I require and two of those are earth and power for the brain.
Now the white wire from the brain (according to the instructions) goes to pin 4 of the central ZKE plug, on mine this is pink, even though the instructions say yellow, then the black/white lock cable from the brain is supposed to connect to pin 17 of the pink plug.
Operated it for the first time and the doors everything locked and the doors are deadlocked (you can't open them using the inside handle) the locked LED with the kit flashing as it should.
But tried to unlock and although I can hear the relay operating in the brain nothing unlocks (first time I did it I locked myself in the car and had to be rescued by my wife!!!)
Have checked all outputs and they seem fine. So I think that pin 17 is the wrong one (lets not forget this is an American system) I have also tried pin 14 with no luck.
So my question is does anybody know which is the unlock pin inside the pink central plug to the ZKE ??
any help would be really appreciated.
Sir P
Thanks for the offer but I'm not even sure if I have an alarm system in the car now. I just started driving it. Up to this point, I had put only 5-6 hundred miles on it in 4 years and that included driving it up from Maryland to Egg Harbor Township, New Jersey. I might be interested in the rear tail lights as when I had to replace some bulbs, the holders looked rather shaky. What are you looking to get for them? FrankieThanks Frankie, currently I am waiting for a missing corner key fob to arrive and if I can get that working I will use that. I don't think you can help me really, but many thanks for trying.
Has yours got central locking from turning the key in the door? If you do, I wonder if you might be interested in the UAS system I have (if I can make the missing corner fob work) It is brand new with two flip key fobs that have the right blade to be cut for ignition, plus instruction CD.
You can look it up on the web it is United Auto Security BMWRSZ2-RH
If the new fob works I will sell the UAS one. With import duty it cost me nearly £200....but willing to take an offer....it is a good system but beginning to think it is no good for a Brit spec car. It is postable.
Again many thanks for your kind offer of help.
Perce
Hi sir p I have repared two broken wires in the boot loom all works as it should from passenger door lock but boot and drivers door only only work together must be another break or something else.View attachment 33469
Boot loom might be a good place to start Geoff....this is what I found when I unwrapped mine;
Sorry Frankie, I had an offer for the job lot that I have accepted....but many thanks again for your help offer, that was kind of you.Thanks for the offer but I'm not even sure if I have an alarm system in the car now. I just started driving it. Up to this point, I had put only 5-6 hundred miles on it in 4 years and that included driving it up from Maryland to Egg Harbor Township, New Jersey. I might be interested in the rear tail lights as when I had to replace some bulbs, the holders looked rather shaky. What are you looking to get for them? Frankie
GeoffHi sir p I have repared two broken wires in the boot loom all works as it should from passenger door lock but boot and drivers door only only work together must be another break or something else.
I'm quite new and I've found its a great bunch of people on here and very helpful .Thanks Mr C. I already like this forum very much.
The wheels are the ones shown in my picture (on the left there) I don't know what they are called....probably should be called "bog standard Z3"
