Is that wide body? From the factory do the wide bodies have the same wheels and tyres as narrow bodies? I ask because, as far as I know, in germany spacers are frowned upon. (No idea what the rules are in Slovakia) So, without spacers, wouldn't a wheel with different offset be required to fill the arches.Welcome to the forum ..looks like mine. Would recommend rear wheel spacers with those style 42 wheels View attachment 236265
zroadster.org
from North Yorkshire.
What size tyres are you running Ant?Mine is a facelift widebody yes. 16" Style 42s with 15mm spacers on the rear. I just think some of the wheel styles don't fill out the arches enough..more on the 16" rather than 17". Yes a different offset would fix that too.
Subtle…we like subtle
Was just getting new track and tie rod ends fitted so took the opportunity to ask the garage to bung on the new rear wheel spacers that have sat in my boot for months. Went for 15mm rear only in the end..a subtle improvement over stock I think. Spacers are PCD hubcentrics…made in...zroadster.org
Are all 4 tyres the same size? Mine are different. Rear is slightly wider than front.
Kudos
Yes all the same size and rims are not staggeredAre all 4 tyres the same size? Mine are different. Rear is slightly wider than front.
The reason we asked about the tyre size is that the tyres on our car seem to be an odd size in that they don't correspond with the tyre pressure info on the B pillar. From memory they are either 205/50 or 205/60 can't remember which (it's the memory that goes firstYes all the same size and rims are not staggered
Yes that's the same as the info on our car so the tyres must be 205/50 16s. Agree that the 17s look better (although the 16s looking pretty good on your car) but we do like the way the car rides on its 16s & as you say 17s are much more expensive, tyres more expensive for 17s also. Never been in a Z with 17s on so will have to cadge a ride in one to get a comparison.Here are the tyre options I can see on the pillar
The 16” tend to provide a bit more comfort and are less skittish … 17” look better IMO.. but are also quite a bit more expensive
No..they are the right size..I have highlighted the tyres I haveYes that's the same as the info on our car so the tyres must be 205/50 16s. Agree that the 17s look better (although the 16s looking pretty good on your car) but we do like the way the car rides on its 16s & as you say 17s are much more expensive, tyres more expensive for 17s also. Never been in a Z with 17s on so will have to cadge a ride in one to get a comparison.
Thanks again for the info, Ian & Sue.
Sorry NoroB didn't intend to hijack your thread.![]()
Sorry Ant not making myself clear. Yes your tyres are the correct size. What I was trying to say was that the door pillar info on our car is the same as on your car, the size of the tyres on our car are 205/50 16 so according to the door pillar info our tyres appear to be the wrong size.No..they are the right size..I have highlighted the tyres I have View attachment 236787
Haha no prob. Actually I've learned something new. CheersYes that's the same as the info on our car so the tyres must be 205/50 16s. Agree that the 17s look better (although the 16s looking pretty good on your car) but we do like the way the car rides on its 16s & as you say 17s are much more expensive, tyres more expensive for 17s also. Never been in a Z with 17s on so will have to cadge a ride in one to get a comparison.
