heater problem
Don7778
The arm on the side of the heater core box that controls the temp is stuck in the closed position. What could cause this and what is the fix. This problem was intermittent for a while but not it is stuck solid
Don7778
The bowden cable may be snapped or siezed
The cable is free. It is the arm on the side of the heater core box that is stuck. I have removed the control cable from the arm. The arm itself will not move.
Don7778
My guess is that something, a twig or such has got into the air duct and has physically jammed the flap inside the heater box. Can you see anything with an endoscope attached to your phone maybe?
https://www.ebay.co.uk/itm/2M-5M-Se...cd2064b6d:m:mr8pXFTkONHH1e-Eo7Pf--A:rk:4:pf:0
Something like this, I have 2.
I,m traveling right now but do have an inspection camera on a staulk. Will try to look when I get home. This problem was off and on for a while so don't know if a twig would act like that. It looks like a good portion of the dash would have to be removed to get to the heater box and open it up.
