ok this has now got me stumped and iv ran out of ideas..
iv replaced the water pump and the thermostat....re filled bled the system using the bleed screw and heater fan on
ran it checked it... topped up if necessary.....its not got any leaks and the coolant level remains normal.
now the warm air only comes through the vents when the engine is revved and if left to idol will over heat with cold air coming through the vents and then cooling fan doesn't trigger..
is this an air block?...now this car has just done around a 1000 miles over the last 3 days...if it is an air block the surely this would have shifted with all them miles....?
ideas would be of great help here?
cheers
swamps
cheers
swamps
