So, after following the hardtop fitting instructions, (which were very helpful) I got my hardtop sitting nice and firmly on my car (even if it is with the wrong bolts!)
Took it for a drive and no rattling or shaking but once above 70 miles an hour, the wind noise which appears to come from the front, is really loud.
I can put my hand in front to me and feel no drafts/gaps, so I’m guessing it’s noise generated by the air going over the front lip of the hardtop.
visually, the hardtops sits flush with the top of the windscreen, but I’m just wondering if it’s too far away and if it should be much closer to the top of the screen.
as you can see from the pictures, I’ve got 10 or 11 mm of rubber visible along the front of the hardtop before it meets the screen frame
if anyone could have a look (in the daylight tomorrow) and post any pictures of how tight their hardtop fits up against the windscreen frame, then would help me to either eliminate or assume that this is causing the noise.
See how the hardtop lines up exactly with the front edge of the rear panel/wing.
It looks like you need to move forward 2-3mm.
my calipers are at shop. But imperial machinist ruler for reference.
how is window sitting in jamb? Mine needs to slide back 1-2 mm on LHD side.
so picture 1 LHD is too tight.
Picture 2 RH side is perfect on mine.
Picture 3 shows LHD window gasket needs to slide back a ‘scootch’
I think 10/32 x .7913 or 8mm is my target.
also, check A pillar gap for noise source prior to moving. If any gap, try putting piece of something to seal it up.
“3. Ensure two rubber mounts are on the inside of the hardtop.”
Anyone have picture or video to share of the above?
is it this p/n 54218163055 ?
I had time for garage today…. I found couple things related to rattle of hardtop.Awake old thread..I too am searching for a noise and leak free hardtop adjustment spell. Lots of try and adjust I see. Thanks!
The bump stops for the soft top, another member also found these to be crushed down think this is likely to be the age of them,I had time for garage today…. I found couple things related to rattle of hardtop.
1. Upon review of the fitting guide, the post can be adjusted vertically. I found one post on passenger side was loose. Not real loose, but loose.
2. The soft top frame has some hard bump stops. I put rubber pieces on it to dampen rattle. See picture.
3. Adjusted the Driver LH side up, about 2mm. Which now allows window to tuck under door jamb gasket. This side also needed tightened.
4. Inspected the OEM defrost connector and found one of two wires unplugged. Cleaned and plugged in.
5 inspected rubber bumpers on rear and found them to be pretty stiff. Placed small foam piece to help aid vibration noise. Supplemented the rear painted ‘mantle’ the top rests on, with helicopter tape/film to prevent chafing.
These foam pads are temporary.The bump stops for the soft top, another member also found these to be crushed down think this is likely to be the age of them,
So what we decided to do was to fill the voids with a piece of rubber tubing this then pushed the bump stop back as close to the original position this in turn stiffened the bump stop this help to eliminate rattling (maybe worth a try)
To be fair your stops don’t look too bad ?
