Glad to see you are still saving these beautiful cars, my MOT tester last week was extremely complimentary about your work on mine https://zroadster.org/threads/taffdaddys-2-2-schnitzel.39743/
zroadster.org
Many thanks, good info.
A combination of standard dampers and struts (OEM or aftermarket) with refurbished Sport springs seems the way for me to go. I would assume that the reduced damping effect would not be noticed by most drivers and the 15mm reduced stroke to closure of no real concern (Sport springs are 15mm shorter and probably slightly stiffer that standard ones). The bump stops may get hit a bit more often that's all!
BMW have confirmed to me that Sports dampers and struts are available. Odd, because I thought they were no longer available a while ago. This would be an option, but price could rule it out compared with alternatives. I'm currently waiting on feedback from BMW on who their manufacturer is and dates they were made before committing either way.
Cheers,
I am glad I found this thread. I have just taken on a 1998 Z3 that hasn't been looked after very well over the past, well, 16 years really.
Gave it an oil and filters change today, and a set of plugs, but it needs some work.
This thread is going to be an excellent guide to get me going
I'll attach a couple of pics to show you what I mean...View attachment 293917View attachment 293919View attachment 293921View attachment 293923
Thanks for the encouragementoh wow. Please share more photos of your progress, that will be very testing. Bear in mind there’s always a way to remove things even what it looks like that.
Another great write up guys and first class work as usual.
@Lee be interested on an update on the brake pipe fittings you are using.
Stephen.
Unusual to see compression fittings on brake pipes, but, as long as they don't leak under a pressure test they can't fail them. Some would advise maybe?
I was with Tony never seen this type of fitment on brakes.
I have looked into it this is what the manual say regarding repair of metal pipes View attachment 293951
You may find a number of tester will look at them and just fail it as a unsuitable type of connection as it is not what they usually see on pretty much every car that is out there going way back.
Stephen.
