As it’s raining today, thought I would play in the garage !!!
Due to a problem with the sump nut when I first got the car, it had two engine oil changes about 2000 miles ago so I know that’s all ok, and since doing the rocker gaskets no leaks.
Coolant was done when I did the thermostat ( about 2000 miles ago) and the system was flushed at the same time. Level when cold has remained at the correct level.
The brake / clutch fluid colour looks pretty good so will leave that for now.
Power steering fluid renewed when I changed one of the hoses that was leaking.
but unsure about gearbox and diff oils.
The manual refers to ‘specially formulated synthetic lifetime’ gear oil SAF-XO for the diff, and MTF LT-1 for the gearbox and doesn’t need to be changed..... REALLY ??????
Can anyone confirm this???
