Fuel flap
Disky
Apprentice Zedder
Falkirk
sorry to sound thick, but is there some sort of rubber gasket seal on the fuel flap ?
Just went to put some liquid gold in the zed and opened the flap to see Loch Lomond in there,,,,, it was flooded, but thankfully none got in the cap itself...
So, if there's a seal meant to be there, where can I buy one from
Many thanks
Ray
Disky
Apprentice Zedder
Falkirk
Doh, sorry, managed to work out how to use the search ;)
mwpe
Camberley
There is a drain hole in the rubber seal below the filler hole. This gets blocked, you can clear it with a piece of wire. You can just see it at the bottom of this picture.
Agree with above, easy fix:thumbsup:
mwpe
Camberley
You might have to dig the mud out to find the hole. =))
Antm72
South Yorkshire
Mine used go do the same no seal but the hole blocks an easy fix :thumbsup:
Mine did that too.:thumbsup:Compressed air is a help here;)
hard top
Dutch Zeds
Netherlands
Remember someone saying that they did it from under the car with a bit of wire.
hard top
Dutch Zeds
Netherlands
Dare I add a bit of humor here but I put a plastic Goldfish in mine and then went to the only garage near me, out in the sticks, that still fills your car up for you, should have seen the blokes face.......:D
Good idea Steve.:thumbsup: Will also work for the roof motor drains on a Z4 too.
Low Rider
I had this problem until I found some old strimmer line from the works petrol strimmer which had been sold.
I just took my time not wishing to pucture the tube. grass strimmer line is to thin
Yeah, my petrol strimmer uses 3mm line minimum. Always have some in the garage!
Disky
Apprentice Zedder
Falkirk
Thanks guys, what a team, 22:17 and I'm just to go out to the garage and look for Strimmer cord lolol
Going to order the flap seal as well, only a fiver or so,,,,, and the old girls worth it :)
Anyone tell you Ken, these things are addictive? =))=))
