Front wheel bearing
All the dimensions seem to be the same Ian, had me verniers and steel rules out and everything seems the same just the problem of not spinning when the nuts tightened,which doesn’t bode well for a wheel bearing 🤔
It only needs a few thou difference for the bearing to lock-up when the hub nut is tightened Peter. I would return it for a refund.
Cheers for your input Tony, I’m talking with the seller so we’ll see what they come back with
Quick update, the bearings were returned the seller issued a refund without quibbling so not sure if this has occurred previously, ironically the cheaper bearings went on perfectly just hope they last a while!
