GazHyde Administrator Administrator Global Moderator M Power Joined Dec 2, 2011 Points 226 Location Berkshire Model of Z Z4 MR Oct 9, 2015 #1 Anyone know off the top of their head what size the bolts which hold the front cross brace on the 6cyls?
hard top Zorg Expert (I) Dutch Zeds The M44 Massive Joined Dec 5, 2011 Points 213 Location Netherlands Oct 9, 2015 #2 I take it that you are doing your clutch Gaz? Don't know if this helps? External Torx sockets (sizes E11, E12, and E14) http://webspace.ringling.edu/~dplassma/cj/cj.html#step2 How To:
t-tony The Legend Deceased Supporter #ZedShed Joined Dec 31, 2013 Points 226 Location Torksey Lock,Lincoln, England Model of Z E89 Z4 23i Auto Oct 9, 2015 #3 I think he did his clutch a while ago Mike. If you referring to the bolt thread size I'm fairly sure they're 10mm x either 1.5 or 1.25 pitch.HTH. TONY.
Brian4 Zorg Guru (IV) British Zeds East Anglian Crew Joined Dec 23, 2011 Points 173 Location Near Grantham Model of Z Z3 3.0i Auto Oct 9, 2015 #4 @GazHyde. M10 x 20 rear and M8 x 20 front, but the rear are 10.9 high tensile bolts so must do most of the bracing. Phttp://www.realoem.com/bmw/enUS/showparts?id=CN52-EUR-06-2000-Z3-BMW-Z3_30i&diagId=41_1628
