rmoconnor41
- Joined
- May 25, 2021
- Points
- 63
- Model of Z
- 2.8
Finished in Topaz Blue with contrasting beige leather interior.
5 Speed Manual, 99,000 miles. MOT until April 2026
Staggered 17” Style 18 alloys, Electric roof, AC, heated seats, 2 keys, Blaupunkt Bluetooth/DAB Stereo
Manufactured May 1999 and first registered Aug 1999 the car is UK spec delivered to a BMW dealer in the Netherlands. It is not an import; this was a way people avoided VAT back in the 90s.
I bought the vehicle with 92,531 miles in May 2021 and have I used it in the summer months only. It has always been garaged over winter.
Service History and Maintenance
The car has an extensive service history with a lot of work having been done recently to bring it to its present standard.
Service Book
26.06.01 Sytner BMW 10,307 Brake Fluid
23.03.02 Fairfield BMW 14.387 Oil Service
Undated Parkland Toyota Truro 23,716 Oil Service
03.03.06 Ocean Falmouth BMW 39,182 Oil Service Brake Fluid Coolant
12.03.08 Andrew Toms Car Sales St Austell 54,972 Oil Service
26.03.08 Ocean Falmouth BMW 55,130 Inspection 2
01.09.09 Ocean Torbay BMW 63.437 Oil Service Brake Fluid
31.10.08 Ocean Torbay BMW 68.333 Inspection 1
07..09.10 Ocean Torbay BMW 68593 Coolant
30.08.11 Ocean Torbay BMW 71,886 Brake Fluid
09.10.12 Ocean Torbay BMW Mileage Omitted Brake Fluid
28.11.13 AMS Autocentre Paignton 83.301Oil Service Inspection 2
30.10.15 Moores Motors Torquay 90,598 Oil Service
17.06.21 Taylors Garage Droxford 92,959 Oil Service Inspection2
During my ownership the vehicle has been maintained by either Iridium independent BMW specialists, Hampshire or at the Zed Shed. Work done in the past 4 years includes:-
New Falken rear tyres June 2021
New Handbrake Cable July 2021
New Exide Battery July 2021
Brake fluid change July 2021
New door handle gaskets July 2021
Replaced diff oil. July 2021
Replace inner and outer track rods August 2021
Replaced roof microswitch August 2021
Replace aerial grommet August 2021
Gearbox pins replaced at the ZedShed which included new gearbox oil. March 2022
New fuel return line, fuel feed line fuel hose and clamp March 2022
New front and rear anti roll bar drop links Mar 2022
New radiator viscous fan clutch May 2022
Replaced passenger seat bushings August 2022
New Sachs (OEM) front shocks and top mounts July 2022
New Sachs (OEM) rear shocks July 2022
Replaced Windscreen July 2022
Replaced original M steering wheel with a matching one August 2023
New front brake discs and pads April 2023
New N/S/F brake caliper and wheel bearing April 2023
New Valve cover gasket Jan 2024
Replaced power steering fluid April 2024
Replaced both post cat O2 sensors April 2024
New Fulda front tyres May 2024
New diff bush and diff oil May 2024
Secondary air pump delete
New rear beam bushes. https://zroadster.org/threads/the-quick-dirty-chronicles.68521/
Oil Change. June 2024
New fuel tank straps. May 2024
Replaced rear brake lines. May 2024
Headlights restored and wrapped in 3M surface protection film
Vanos seal service including new needle bearings and anti rattle rings. August 2024
New thermostat and coolant change November 2024
New complete PCV valve kit March 2025
Full set of Bosch spark plugs April 2025
New Vanos solenoid – April 2025
New Genuine BMW supplied MAF Sensor. May 2025
The car has very good MOT history with only very minor advisories.
https://www.check-mot.service.gov.uk/results?registration=T239+VVX&checkRecalls=true
Mechanically the car is very strong, but does currently suffer from an erratic idle when cold. Once warm it then runs perfectly.
Bodywork is in good condition with just a few scratches and small chips consistent with its age. There is no corrosion on the sills although there is a small dent underneath on the NS which is only noticeable up on a ramp. The interior is very clean and shows very little wear. The seat belt restraints are both undamaged and the electric seats work as they should.
The original powered roof is still very good and works perfectly with no leaks. I always keep it under a half cover. Sale will include the tonneau cover
Aircon would require a regas or service as it is not something I really use.
I am looking for £4950 or close offer. I will be sad to see it go although I now have my eye on something else. This is a very solid car with all major work completed.
The car is sold as seen and without warranty, so viewing is recommended. I am in SO32 Hampshire about 15 mins from Junction 7 of the M27. I am happy to take any videos you want or do Facetime, Whatsapp video calls if you are not local to me. Any questions please reply here or just drop me a PM
Service Book
