Ah I see. I imagined the cages, single or double DIN had a universal catch system if they were aftermarket.The cages are made for the unit, hence one came with your lads. because the unit has a lock clip matching the cage.
Without that the unit would simply slide out he cage. you can probably by cages separate, but to work, it would need to have a clip that matched the one on the unit. All these unit don't seem to have anything for clipping to a cage (that I can see). It's like they are screwed to the side somehow, but I just can't see how that would would in a Z3, or pretty much most cars... hence why case/frames are used.
Maybe I'm missing something obvious. But I can't see it.
That one is pretty much the same as I have, there are a lot of variants all very similar,I'm settling on something like this...
165.0US $ 34% OFF|Quad Core Android10 1din Universal Car Multimedia Radio Stereo Player Wifi Gps Mirror Link Autoradio 4g Lte Camera Rotatable Dsp - Car Multimedia Player - AliExpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
However, although all 1-din fitting, they don't seem to come with a cage/frame. Just some brackets.
The sides look like this;
I just can see how that would fit without a normal cage/frame
I've even seen in the reviews a pic of one installed in a Z3?!!
(it was just a pic in the review, so I can't even ask the owner!)
Anyone got a clue? I'm just very apprehensive to order and then find I can't get it to fit?
Thank you for doing that @gookah, it's very helpful. I am starting to think a cage might work and that the tooth might slip into the gap where the split level part is.so I checked today and it is in a cage:
this is covered by the trim that comes with it:
the screen and holder is slotted to allow different heights:
It has two clasps that you slide outwards to adjust the height, and a ball fixing that allows it to be swivelled.
Now I am not sure if it came with a cage, or I just used the one from my old Pioneer unit, but either way it is doable and it locks in place.
I tried to remove it with the two Pioneer keys I have, but it wouldn't come out,
So I had to stop there and take the missus out instead...... !
That's a nice one ! What is the reference of this radio ? Thanks in advance.What about a fixed screen single din , mechless, like my pioneer. Doesn’t block the vents, only slightly obscures the heater controls from the driving positionView attachment 193843
