So after trying a few things (tightening hood sealing frame bolts, silicone and Captain Tolly's Creeping Crack cure) I'd almost got rid of the leak from there (the butyl sealant dries out apparently and removing the hood and frame and re-sealing it the one solution (or new hood if you need one anyway)
I don't need a new hood nor able to remove the hood frame and re-seal it...
Then had the bright idea if getting some butyl flashing tape. I got the 100m wide version by Sika from Screwfix (there are plenty of butyl flashing tapes out there).
I then warmed it as it was cold out and proceeded to fix all the way around the hood frame seal and made a double row for good measure.
Seems to have done the trick and can be peeled away when I eventually need to replace the hood.
Might be useful for others out there.
Going to dynamat that area too as a lot of noise comes in there since I removed the carpet (which is very light weight anyway). Will finish it off nicely too as it's a it messy now to my eye even if it out of sight and under the carpet!
Some pics:
Some pics:
