Is it easy to relocate the electric roof switch from the rear panel between the seats to the front with all the other switches? There is a space available and I find it a bit awkward having to turn around to find it all the time!
Well it really does not matter as surely you only put it down once in early spring and then back up again in late autumn!Electric roof ??? I dream of having an electric roof, and I wouldn’t care where the switch was![]()
Only took 1/2 hour. I got bored!!That was quick, thought you were supposed to be taking it easy!
That is easily done, just turn off the pump in the boot and it’s manual!The roof switch in my 2.8 is in the centre console.... And to be honest I would prefer my manual roof I just find it so much easier
You're b*ggered if you want air con nowView attachment 88501 Done! Another job which was a lot easier than I thought!
i had to when it wasn't working.. but theres quite a bit of resistance even with the knob turned... probably better to disconnect the piston..That is easily done, just turn off the pump in the boot and it’s manual!
