Fault code help please
O/S/R is that the one where you damaged the cable Sean?
Nice to pin it down to one all the same mate.
Sean d
Lincolnshire
No mate, it was the N/S front, seems strange that all 3 codes have gone but a new one sprang up, suppose it could have something to do with the drive that I had
Possible mate. Hope it's that simple.
Brian4
Near Grantham
Z3 3.0i Auto
Thats a very imformative and much appreciated post, thank you,
However things have changed somewhat,
When the original codes where read I had had tge car out for a short run and never read the codes again once cleared, today I put the Snap on scanner on and read the codes, ABS is now only showing one code which is
88 right side rear wheel speed sensor open circuit,
So whats happened, these cars have some character to say the least :)
I guess you may have turned the ignition on with the sensors disconnected at some time and perhaps when the brake fluid was drained. Now you have driven it the units have rest themselves except the one sensor. Try @t-tony tip re plugging sensors back in.
Sean d
Lincolnshire
I did turn thr ignition on a number of times when the sensors where disconnected Brian, hopefully I'll get lucky on the rear one as well
Sean d
Lincolnshire
@Brian4 do you know what the resistance of the rear sensor should be, I understand that if they have gone the resistance just keeps going up,
Brian4
Near Grantham
Z3 3.0i Auto
Sean sorry can't remember what mine were . You can measure the at the plug on the side of the ABS pump the pins can be identified in the drawing from @Clockwatcher in post 19. They should all be about the same.
Reverse option is put a volt meter across the two pins then spin the wheel and you should see a deflection on the meter.
Sean d
Lincolnshire
Put the meter on it today and no reading at all, I have removed it ready for a new one on Monday
Sean d
Lincolnshire
New sensor sorted the problem and dash lights have gone, thanks for the help guys
Good news Sean, glad it's fixed mate:thumbsup:
2.2 Sport Individual
...going to take it for a test drive tomorrow...
Take it gently then Sean, go easy on the go pedal, especially in 1st and 2nd;)
....... at least till you know the ASC is working. I left the lights at Drinsey Nook in a hurry last night and this weird orange came on and wouldn't go off till I lifted my right foot. Is this a symptom of something :ymdevil:
I thought it was using steel shoes instead of rubber ones mate =))=))
