Came across a thread on BF about the fan delete again and am thinking of doing it as described in point 1 below.
I've had the viscous coupling go as well as two fans disintegrate (nearly puncturing the radiator). Already spent plenty on this fan set up an wonder when it will fail again...
Seems to work fine in US temperatures so should be fine here (although it does get rather balmy here in Kent).
Thoughts anyone?
Thread here:http://www.bimmerforums.com/forum/showthread.php?t=2168137
Thoughts anyone?
Before doing this is I'd want to be sure my electric aux fan is working though as I can't say I've ever noticed it working before (or is too far forwards to be heard from inside the car?)BenFenner;28414668 said:Randy should correct me if I'm wrong, but there are three common practices regarding removal of the mechanical fan.
Edit: Damn, I was trying to get this post in before Randy replied. =/
1) Remove the fan, and do nothing else.
The engine coolant loop system will reach the minimum operating temperature (dictated by the thermostat) quicker (which is a good thing). The system will hold minimum operating temperature by mixing in the rest of the coolant via the thermostat until the entire volume of coolant is up to operating temperature. At this point, if you're not moving through the air the coolant temps will continue to climb to optimal operating temperature (which is some point higher than the thermostat rating, but below the boiling point of pressurized coolant). If you're still not driving through the air to cause the radiator to cool, the coolant will eventually creep up to the maximum operating temperature dictated by the fan switch. This will turn on the electric auxiliary fan which will move air over the radiator and cool the fluid.
The only difference in behavior from stock will be that you will reach minimum operating temperature sooner, and if sitting still, you will reach maximum operating temperature sooner, at which point the electric fan will turn on.
This is my preferred and recommended solution.
2) Remove the mechanical fan and replace the thermostat with a slightly lower temperature unit, and replace the electric fan switch with a slightly lower temperature unit.
The engine coolant loop system will reach a lower minimum operating temperature (dictated by the lower temp thermostat). The system will hold this lower minimum operating temperature by mixing in the rest of the coolant via the thermostat until the entire volume of coolant is up to this lower operating temperature. This is a bad thing. Fuel economy and emissions suffer. At this point, if you're not moving through the air the coolant temps will continue to climb to optimal operating temperature (which is some point higher than the thermostat rating, but below the boiling point of pressurized coolant). If you're still not driving through the air to cause the radiator to cool, the coolant will eventually creep up to the lowered maximum operating temperature dictated by the lower temp fan switch. This will turn on the electric auxiliary fan (too early, which is also bad for fuel economy and emissions) which will move air over the radiator and cool the fluid.
The difference in behavior from stock will be cooler steady-state operation (which is not ideal) and a cooler upper limit (which is not ideal).
This solution never made any sense to me. The only time it ever makes any sense is if you live in Death Valley and occasionally see a slight overheating issue. Lowering the steady-state and max temp range only buys to 30-90 seconds under these conditions at which point you will begin to overheat still. If the electric fan can't handle your cooling needs, no amount of lower thermostat or fan switch will help. And it only hurts (see fuel economy and emissions reasons).
3) Remove the mechanical fan and replace it with an electric fan.
It should be obvious by now, but the only reason to do this is if you live in Death Valley and sit at stop lights for long periods of time with the A/C on. 99% of owners will not require a second fan. To do this properly, by the way, this second fan should be triggered to turn on at the same temperature as the stock auxiliary fan (or thereabouts). Otherwise you will be treating one of the fans as a fail-safe, which doesn't make sense either, and/or you will be unnecessarily narrowing your operating temp window.
