Exhaust bracket rubber
Dino D
Kent
2.8 Manual
I have an increasingly annoying rattle that I have scientifically pin pointed to this bracket (by lying under the Z which I couldn’t get up very high and tapping the whole exhaust with a rubber mallet and wondering why I didn’t wear my goggles (of which I own three pairs..)
Luckily I only needed my ear so being blinded and chocking in crud didn’t stop me...
Thankfully this bush doesn’t seem too bad to get at and as my exhaust is a two piece should be ok to do, provided I lift the car higher. It seems the rubber bush slid too far inwards or just collapsed/perished and allowing metal on metal contact which causes a lovely rattle at cruise...
Anyone changed this bush - anything special about it - can’t get a number for it on realoeam but it looks like many other bushes so could get any brand like powerflex etc?
You should be able to get a new rubber from an exhaust fitting outlet, preety standard type of rubber.
You need to stick to a rubber replacemnt as it insulates the exhaust from vibration as well as supporting the exhaust.
MalcQV
Manchester, UK
I have just changed the rear section but that was the last hanger the exhaust was on. I had to pull the rear section towards the rear of the car to release. However I am sure you can manipulate the rubber hanger off on its own.
@Dino D
The bracket that the rubber attaches to bolts on, check its tight before you buy the rubber as if its loose the new rubber wont cure it...just saying. :thumbsup:
