bmwz3tower
- Joined
- Dec 5, 2024
- Points
- 29
I'm getting power to the solenoid (I can hear it click), but the starter won't crank the engine. Has anyone experienced this/ does anyone know if this maybe an EWS issue.
Sorry, should have said in the question, I've removed the starter, cleaned and regreased it and changed the solenoid. Prior to this, the non starting only occurred when the engine was hot. Now it just won't start. I've got a suspicion the solenoid may not be the exact same model.Starter motor likely. Give it a decent tap with a hammer and try it.
Bit more info, the battery is at 12.1V so should have enough juice to turn the starter. I have also tested the starter and new solenoid outside of the car (with same battery and it worked). Finally, have connected a multimeter to the copper strap that goes to the starter brushes and found that when turning the key, the starter does not get power.
Thanks, that was my next move.12.1v is flat, very flat! You need to give that a good charge or get something to jump start from.
The 1.9 M44which engine is it?
I've already done the first 2 with no luck, so I'll try the 3rdget a jump lead and clip it between the engine, lifting eye maybe, and the chassis stud on the strut top. Try to start. This proves the negative strap to the engine.
Inspect and clean Battery negative strap between clamp and where bolted down to chassis.
If neither of those, using a nice big screwdriver, short the two big studs on the back of the starter motor. Expect it to crank over. This will prove high current supply to starter. Don't assume measuring 12v there will actually spin the motor if there is a resistance in the system.
