Error code 2002 z3 1.9
Bobbybiscuit
Plymouth
Z3 1.9 E36 M43 4 cylinder 118 HP 197 km/h 2001 - 2003
Just connected up a new scanner and got the following error codes:
1) F5 CAN bus ASC 1message not sent ( i did have an issue with another Connector - replacement works)
2) Voltage supply Terminal R faulty. The carly scanner says there is too much voltage coming out of the postive terminal.
Can you please explain what these codes mean please in simple english
Thanks
PS I have also the dreaded air bag code (70) but apparently quite common. So ordered a emulator.
Zephyr
Terminal R faulty could be a seat occupancy sensor. Had a long time ago on an E46. a tech discovered it and solved it.
other than this the terminal R is the Run position of the key (second click before start) and the ecu checks static data in order to switch off the warning lights on the dash.
if a warning light stays on, or there is an actual fault in the terminal this error appears.
check your battery, erase codes and try again.
Bobbybiscuit
Plymouth
Thanks for information. I will give that a try. The onloy thing i dont understand is why the carly app says there is more coming out of the positive terminal than going in. I have checked the voltage across the terminals with a voltmeter and its within the permitted readings.
Zephyr
sorry no idea about this. How did you connect the carly? Where is the adapter plugged to? Engine obd or cabin?
Bobbybiscuit
Plymouth
Cabin - the connector to Engine was non functional. I will try again tomorrow and see what I get.
Thank you for your input.
Zephyr
do this little hack to the engine obd. Connect with a wire these two guys and plug it back in. Then read again from the cabin. you will be very happy looking at all available codes from inside the cabin.
Bobbybiscuit
Plymouth
Thats a great hack. Does the pin part of it just pop up ? (lever it up?)
Zephyr
the pins are protruding and are solid. If I understand correctly what you are asking, just put the wire there and plug it back. once you open it it will be obvious. Easy.
