Hi
One for the breakers!
I'm looking for all or some bits of an engine wiring loom for the M52 6 cylinder engines. Specifically one that used the Siemens MS41.0 DME, ideally from a M52B28, but I think all the M52 engines between 1995 and 2000 used the MS41.0.
I actually only need the DME connector and a couple of feet of the loom, and the Diagnostics connector. They don't need to be connected.
It's not for a car, I want to build a bench loom to power up and program the DME's. Having a test cable would be a lot less hassle than pulling my car about each time.
What have you got?
What have you got?
