Sean, I’ve seen the s54 advertised for £2800 to £3500, I’m just trying to establish what else I’d needYou'll need a mortgage to buy anS54b32, I looked into it a few years back and decided it was viable
When I looked it was around 5k just for the engine and at the time you could buy an m for less then 10kSean, I’ve seen the s54 advertised for £2800 to £3500, I’m just trying to establish what else I’d need
Thanks Lee,You’ll need the engine loom to match the engine. The Ecu will need to be from the S54. Also mounts from the S54. Because they actually made these to fit the Z3 you can still pick up what you need new.
I’ll drop the question about subframe in an engine swap group chat I’m in. I’m pretty sure you don’t need to. As for the aircon I would try swap over the pump and keep the system sealed they might use the same pump. Something worth looking into. Also the 5 speed ZF box mates up to the S54.
