Engine missing then will not start
britlad
Kent, UK
1999 2.8 dual vanos After a long time in a jam the engine started to hunt on idle and then stop. when I got moving the engine was misfiring even at 40mph. A few miles further no problems then when I stopped misfiring again. When I got to destination it would not start again. Error codes cam sensor and Fuel train bank 1 and bank 2. I changed the inlet cam sensor recently but not a BMW item but unsure of fuel train bank.
Any suggestions please
Michael
Check codes again. Likely cam sensor or connections.
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
3.0L, 2.8L, 2.0L Z3 Roadsters
Your fuel trims bank 1 & 2 may be telling you that there is a vacuum leak. With a warm engine at idle look at the short time fuel trims, >8% means a vacuum leak. If you rev the engine and they reduce, that confirms it.
Usual suspects are:
- rubber boot from MAF to throttle body/idle control valve. The small tee off to the Idle control valve tends to crumble with age.
- rubber caps on the back of the manifold that split and leak
- hoses for the Crank Case Vent system
