That's why you took it easy on the Xmas cruise then Steve... they were past it,with the thread material showing on the near side tyre...
Yes I was pleased with the brake test as well,they are working superbly after you worked your magic on them.No Brian, I'd have to give the big lad a pass on that. I was just happy to see excellent brake test results!
It's a good job it was a steady run Dave .That's why you took it easy on the Xmas cruise then Steve
It's all those wheel spins you do Niall pulling off from the lights etc .20k from a set of rears you lucky sod Steve. looks as though I'm going to be lucky to get 10k out of mine its following @mid life crisis all year that's done it
Absolutely mate,could be a lot worse.I'll take an MOT fail with tyres over an emissions failure as it's an easy fix.
And a chairHope you had a nice cuppa off the tester before he gave you the bad news!
Its extremely hard to spin the wheels in the dry unless you abuse it ...great fun in the wet though with no traction control Continentals all round. she will have Michelin Pilot Sports next time which is what I should have stuck with haven't liked the conti's since they went onIt's all those wheel spins you do Niall pulling off from the lights etc .
What make of tyre do you have ?.
Steve
Steve knows where I planted the blame on wearing out his tyres Niall. Something about following a crazy Welsh man around the valleys.20k from a set of rears you lucky sod Steve. looks as though I'm going to be lucky to get 10k out of mine its following @mid life crisis all year that's done it
Also exactly what I said to Steve this morning Niall, wet weather eats tyres worse than dry if you're not careful.Its extremely hard to spin the wheels in the dry unless you abuse it ...great fun in the wet though with no traction control Continentals all round. she will have Michelin Pilot Sports next time which is what I should have stuck with haven't liked the conti's since they went on
Totally agree but the wet weather brings the child out in me .... I just can help it TonyAlso exactly what I said to Steve this morning Niall, wet weather eats tyres worse than dry if you're not careful.
Me too mate but thankfully the TC saves me from being to bad. God know what would happen if I turned it off, I suppose tyres wouldn't be too huge a problem though.Totally agree but the wet weather brings the child out in me .... I just can help it Tony
Toddleblob! Who's it aimed at then!After posts about certain tee shirts recently, Shirl just popped up with this diamond, and this is aimed at no one person directly, but I thought I should share.
