Charlie Fryer
Help please, (51plate, 1.9 wide body)
1. what fault code readers are people using? I don't want to spend a fortune for something i may use rarely. (aware i need the 20pin type)
2. Car alarm goes off after locking by key fob, but not when turning key in the lock. Someone before mentioned a switch/relay behind the passenger seat under the hood. how do i get to it?
3. Started the car in the warm weather went to blip the revs and it cut out wouldn't start, had to lock and unlock with central locking and then it started, blip the revs cut out again did the lock/unlock re started......could that have been something to do with having the brake pads off with wear indicator disconnected?
