Tom Holland
- Joined
- Jun 28, 2017
- Points
- 49
Neither Tom. The system early cars had was ASC (Automatic Stability Control) and later cars have DSC (Dynamic Stability Control). Your car will have one or the other....Sorry to sound a complete numpty but the DSC is the cylinder and black box? The ASC is the wet part the pump?...
Thank you you can see I'm not so good at thisNeither Tom. The system early cars had was ASC (Automatic Stability Control) and later cars have DSC (Dynamic Stability Control). Your car will have one or the other.
Indeed. That's why I said perhaps there are some alternative builds. And to check the centre console button.Guys guys guys - we are all getting confused there are TWO versions of the DSC on the Z3's early DSC cars come with the module on the left hand side of the car whereas the later version of the DSC equipped cars come with the unit on the other side of the engine bay, but they are both DSC. This is all down to a later development where they integrated some sort of pre-charge pressure pump on the unit whereas the older units had that pump as a separate item or something along those lines.
BTW my 3.0 is a DSC car and it has the pump on the same side as Tom's
Maybe the ASC equipped cars also have the unit on the same side of the early DSC ones, I am not familiar with those.
That's what error codes are for You'll soon get used to us lot saying read off the errors before plotting any furtherHello Mario, that's the trouble, was my original sencor bad or was it the DSC or is the new bad or all bad or all good and the rotation sencor. It's a laugh!
Thanks for the link, unfortunately I got the round type. This is the codes from the auto electrician. He then said I have checked the wiring OK, think it's the Abs. So here we are. I'm sure the guys will sort it out. The previous owner was quite insistent the car was made in Germany! Is that possible?That's what error codes are for You'll soon get used to us lot saying read off the errors before plotting any further
This sort of thing will take you a long way (C110+ Creator)
C110 Scanner Airbag ABS Engine Diagnostic Fault Code Scan Tool Reader OBD2 Suitable For BMW Cars: Amazon.co.uk: Car & Motorbike
Buy C110 Scanner Airbag ABS Engine Diagnostic Fault Code Scan Tool Reader OBD2 Suitable For BMW Cars at Amazon UK. Free delivery on eligible orders.www.amazon.co.uk
Not everyone wants to get into that though I know. But whoever repairs it won't get far without one.
Yes. As long as you buy the BMW version. I think it may be available for other cars too.Thanks for that, I will definitely get one and an adapter. So the bmw codes will appear on this reader?
