Hey all
Just had a fail on mot for high co2, failed being .5 (should be .3).
To be fair the car is running quite rich to the point the exhaust at idle stings your eyes!
The cars always had a lumpy idle, but drives great!
I’ve literally had to get back to work, so I got back to dropping the car off and sprayed some carb cleaner around the vacuum hoses I could see, plus on the intake bellows after the maf sensor.
Ive ordered a replacement ccv valve and the hose that goes to the rocker cover as it’s quite squashy! The idle did seem a little better when I unplugged the maf sensor, but didn’t have time to drive as couldn’t be sure, although the exhaust didn’t seem so fumy!
I have a smoke pro at work so will give this a try on the vacuum hoses.
The maf sensor seem very expensive on these? (EBay)…would anyone know where I could acquire a good used one? I’m in dover.
Sorry for the rushed explanation, but I need to get back to work!!
Thank you
Thank you
