Drain
Cooper
Australian Zeds
Hobart Tasmania Australia
3.0i 2001
Yes. down the very bottom at the back. You might have to use a piece of small wire to unblock.
Strimmer cord works a treat then some hot soapy water
5harp3y
as the others have said, its very small and often bunged up with crud.
i make a habit of wiping that area clean every time i wash the car
Whilst your at it check the drains where the hood hinge is on either side, takes a bit of finding but its within the metal well that the hinge pivot sits and a rubber pipe runs down to the underside of the car just in front of the rear wheels on either side. If you can't see it from above have a look underneath for the end of the pipe. A little water poured into the top well and you should see it trickle out of the pipe underneath the car.
Jjim
Mansfield
1.9 Roadster
This has reminded me I need to sort mine out!
hard top
Dutch Zeds
Netherlands
Mine kept getting blocked, so I would stick paper towels in there when filling up at the garage.
Keith Lowes
Instow,North Devon
Any chance of a picture for location?
hard top
Dutch Zeds
Netherlands
@Keith Lowes, Posted by @TaffZee
Nope there is an internal drain hole just under the gap shown on Dino D's Photo. It is in the form of a type of open box section that collects the water from the hood and channels it into a drainage hole.Proof at last..
#5TaffZee, Jan 19, 2015
