Some of you may know that when I bought my Z3 a few months ago there was an issue with the door locks. I was given a single master key for the car. This key has no buttons, just a bog standard key. The key would only turn one way in the door locks. On the drivers side it would unlock, on the passenger side it would lock. You physically could not turn the key the opposite way in the barrel. The key works fine on the boot lid and to start the car.
After much head scratching and pulling out the barrel from the passenger door handle it was decided that the key looks to be so worn that it is not operating the barrel correctly in the doors. With the barrel out we could see that when the key is inserted, the blades all retract as they should, apart from one. This one little blade would not go in. You could push it in with you hand so we know the key is correct for the barrel, just not operating it correctly.
Armed with this knowledge I called Sytners and explained that I wanted a cheap key with no buttons for my car. A key was ordered and two days later picked up. When I tried the new key in the doors it works like a dream (almost). The key will now turn both directions in the door locks and will start the car. Unfortunately the drivers side does not lock the car, nothing happens. I need to take the handle out and see what is going on there. The key also will not go in to the boot lock. Physically, it will not go in. Another trip down to Sytners and it turns out that what me and the guy on the phone had actually come up with was a cheap key alright, it is the service key. Will operate the doors and the ignition but not the boot lid or the passneger storage boxes. Doh!.
The parts guy at Sytners was very good though. He went and looked further in to avalable keys and saw that there is a master without buttons and offered to order me one for cost price so another key was ordered. This arrived today and works perfect, works in all the locks. So the only issue I have now is that when I turn the key in the drivers door to lock the car, nothing happens. Luckily I still have the door card off the drivers side so if the weather is kind to me at the weekend, this will be my weekend job.
As an aside, I can get a full master key from Sytners. This has the buttons on the key and they have said that this should operate the alarm and the remote central locking on the car. It is a 1997 1.9 which I thought needed a separate box to activate the alarm but if this one key will do everything then it is certainly on the shopping list. The downside is the price, currently £178.
I thought I would share this tale with you all in case anyone else comes across the same issue with the key not working as it should. I hope someone finds this of use.
