Correct. And I expect it will at some stage whether it's 2 days or 2 months down the line.If that is the case then the light should reappear shouldn’t it?
If it's an air leak in the MAF hose you may not get a more specific message. The misfire may be as good as it gets.
It's a very common issue, the rubber just rots and cracks. The crack can open and close.
It may not be that of course. But it's quite simple to check and replace if it is.
