The final chapter with Dave's 2.2 came to a satisfying end yesterday.
We split into two teams to speed up the last day. We had alot of ground to cover and luckily a full garage of 8 people, despite the cold everyone came out to play.
I got started on fitting the rear back plate without removing the hub. I cut a 20mm slit at the bottom allowing my to twist the back plate and slide over the existing hub, this worked well because the handbrake guide clamps over the slit I made.
I then moved onto fitting the new Eibach springs, refitting the roll bar, Tightening the prop shaft nuts. Rob & Dylan was the other side doing the same. We had a very strange situation with the handbrake cables (they keep changing the design slightly over the years) They have fitted a PTFE sleeve on the end which was too big to fit through the hole into the car. I ended up sat there with a blade trimming them to fit.
Gaz was having fun up the front, it was so cold the rubber had shrunk on the lollypops making it near on impossible to fit them to the wishbones. With some gentle heat they then slid on no problems. He also found the front springs were also cracked and the shocks were original.
We also had a sized front offside calliper luckily I had a relatively new one on the shelf to swap out.
Overall under the car there's still quite a bit of light surface rust but nothing substantial the nuts & Bolts have taken the brunt of the corrosion. Last thing we did was bleed the brakes fit some spacers and get her out for a test drive. There was one last little touch that quite a few members have recommended, just something for a little fun.
We had a couple of minor noises on the test drive: 1) being the rear arch liner caught the wheel, this was not sat in the arch correctly. 2) front dust shield caught the disc on full lock, again another easy fix. I also could feel the age of the tyres causing interesting handling in the rain at 70mph, they're very old and miss matched, Dave's plan in the coming weeks is to get the wheels done and fitted with fresh rubber.
Overall a lovely car to drive, the 2.2 engine is very crisp and responsive, must be down to the welsh contingent sorting the air leaks my 2.2 never drove like that.
Zedshed out
