Copy brake pipes
That’s genius although it would only work with short brake pipes unless you have a huge open work space. I might grab one and give it a go.
Useful if you’re on your own but if there are two of you it’s not needed.
  • Like
Reactions: Lee
It’s really simple like me ,and easy to make,could probably fix something to a workmate and use it outside nice idea
If using Kunifer pipe it could be useful but if you're using copper you really only need your hands.
  • Agree
Reactions: Lee
When I used to make up front to rear pipes out of copper I just flared one end as per the pipe needing replacing and simply unrolled the coil of pipe and made the bends as I went along. It's really easy using copper, you soon get the hang of it.
