25 (twenty-five) is the natural number following 24 and preceding 26.
It is a square number, being 52 = 5 × 5. It is the smallest square that is also a sum of two (non-zero) squares: 25 = 32 + 42. Hence it often appears in illustrations of the Pythagorean theorem.
25 is a centered octagonal number, a centered square number, and an automorphic number.
25 percent is equal to
25 has an aliquot sum of 6 and number 6 is the first (or smallest) number to have an aliquot sequence that does not culminate in 0 through a prime. Twenty-five is the aliquot sum of three integers; 95, 119, and 143. Twenty-five is the second composite member of the 6-aliquot tree.
It is the smallest base 10 Friedman number as it can be expressed by its own numbers: 52.
It is also a Cullen number. 25 is the smallest pseudoprime satisfying the congruence 7n = 7 mod n.
25 is the smallest aspiring number — a composite non-sociable number whose aliquot sequence does not terminate.
According to the Shapiro inequality, 25 is the least odd integer n such that there exist.
Within base 10 one can readily test for divisibility by 25 by seeing if the last two digits of the number match 25, 50, 75 or 00.
Titan will have a hard on now..............
