Following on from my concerns I thought that I would do a bit of a pictorial write up to help others do a bit of preventative maintenance
OK, first up is a shot of the part that makes our S50 engine such an addictive thing own. The S50 Rolls Royce VANOS (variable Nockenwellensteuerung) variable camshaft timing device.
There are two packs of twin solenoids that operate on the exhaust and inlet side of the cylinder head. This write up deals with the LHS exhaust solenoids, but the same applies to the RHS, only difference is you need to remove the fan to get the whole cowling out
To get to these its best to create a little more room and remove the radiator fan cowling. the LHS is secured by a push rivet and then it lifts up and pulls out
Now, below the alloy vanos is a black plastic cover secured by 2off 10mm nuts - remove these and remove the cover to give access to the plugs for the Solenoids
Here is the plug
So, pinch the metal clip and pull out the plug
Once removed we can now remove the cover, first up make sure you put some paper towel or cloth down under the cover as some oil will come out when the Solenoids are removed. If you get oil coming out when you remove the cover then this indicated oil seal/O ring failure.
Now,you need to remove the valves. There are fitted rather snugly so you need to tease them out. I used a pair of soft jaw grips. Note the position of them and mark/photograph as needed.
Now, there are four wires on the SV's, two on each and three on the plug - two wires are common
Use a contact cleaner to remove all the trace oil
Next is to check the coil resistance - This reading of 3.3 ohms is good. If there was no reading then this indicates a failed coil
A common failure is the soldered connections to fracture so I re-soldered them and bridge the solder to bypass the copper connection on the printed circuit board (copper link can fail too)
Its time to fit the replacement O rings on the valves now.
Once the O rings are changed, clean out the oil from the SV housing as there will be residue in there
Now pop the valves back in, taking care to fit them in the same place as before. The click home securely
Refit the cover along with new paper gasket and torque new bolts to around 8-10Nm
The refit is the reverse of removal, ie refit the plug connector and plastic guard.
Once you restart the engine, it will be a little lumpy for a few seconds whilst the oil pressure in the vanos builds up
Job Done
Hope that helps! Just do the same for the RHS now.
