Assuming the loom of doom is ok then you need a passenger side door actuator.Right, when I unlock on the passengers side (with key) it unlocks both doors. If I do the same on the drivers side it only unlocks the drivers side.
What do I need to fix
TIA!
the loom of doom is the small loom runs from the car to your boot lid, there are several wires in there that become brittle, short out and cause havoc. By the sounds of it I don't think you have to worry about this.tell me more about the loom of doom? my airbag light is on too....
Great info Muzz, thanks for postingHi
Having spent more than a hour or two fixing Z3 central locking faults the following may help you with the quick easy fixes.
A little bit about the Z3 central locking:
- All locks (drivers, passengers and boot/trunk) work the same. If you use the key to unlock anyone, all the others should unlock. Same for locking. So, locking the boot/trunk with your key will lock all doors.
- If one lock does not work when all the others do, then only fault find at the lock that is not working.
- The loom of boom impacts the operation of the boot/trunk locking only.
- Each door has two different sets of contact that need to be working correctly for the central locking to work at that door:
a) Door striker switch (open and closed contacts) located behind the door striker pin on the car jam. Its a little black square. It you need to replace it, remove one screw at a time as the backing plate will fall into the dark pit of despair if all screws are removed at the same time.
b) Door lock position (locked and unlocked contacts), part of the door actuator and hides behind the door handle deep in the door cavity
- Using INPA helps identify the contact or item that is not working as you can see the contact positions change etc.
If no doors or boot/trunk work on the central locking, then that's a more in-depth topic.
Hope this helps
Regards
Muzz
Good info, do you have any ideas about increasing the range of the remote? It's not worth having when sometimes the door lock is within arms length by the time the bloody thing works!!Hi
Hope this helps
Regards
Muzz
Think it's a key battery thing.Good info, do you have any ideas about increasing the range of the remote? It's not worth having when sometimes the door lock is within arms length by the time the bloody thing works!!
Good info Murray however the loom of doom has the potential to upset a few things, not just the boot lock.Hi
Hope this helps
Regards
Muzz
Try changing battery in fob - mine's the same as the battery ages. With a new battery installed I can switch it on and off from inside the house with the car in the garage - accidentally at times!Good info, do you have any ideas about increasing the range of the remote? It's not worth having when sometimes the door lock is within arms length by the time the bloody thing works!!
Many of the Japan market Z3's have the Infrared Remote Central locking (check your Vin Decode for option 875) and not the RF Remote central locking. The Infrared system requires a line of sight to the clown nose on the bottom of the inside rear view mirror, so the range is very short. The RF system has a far greater range as it does not need the clear line of sight to the mirror. Its range is more dependent on battery condition.Good info, do you have any ideas about increasing the range of the remote? It's not worth having when sometimes the door lock is within arms length by the time the bloody thing works!!
Yes the Loom of doom also affects other systems, My comment was written from the perspective of the central locking system only.Good info Murray however the loom of doom has the potential to upset a few things, not just the boot lock.
If the wires for the central locking short in the boot loom this doers affect the whole central locking system.Yes the Loom of doom also affects other systems, My comment was written from the perspective of the central locking system only.
Hi Muzz,..............Suggest you connect your car to INPA and check the central locking operation of the door position contacts and the lock position contacts. Its easy to see the contacts swap condition as you open/close the door or un/lock the door as the black dots change to white and visa versa. If one of the black dots does not appear e.g. you have two white door position dots, then you have found the culprit...........
