Central locking not working
si-forks
worcester
I know this is a common fault and is normally down to the boot wiring loom but I've checked the wiring in the boot and all is fine.
The car will all unlock from the passenger side but from the drivers side door ,only the door and the boot opens not the passenger side door, the wife just think I'm trying to keep her out!!!
Is it the central locking actuator and if it is which side do I need to replace thanks for any help
Si-forks on tapatalk
Aceman
Moderator
Wakefield
///M Roadster
From what you say your symptoms are the fault is definitely on the passenger side. Firstly as you can open from the passenger side your actuators and wiring in both drivers and boot doors would appear to be OK. I would suggest it is either the wiring in the passenger door (positive feed to actuator) or the actuator itself. It shouldn't be too much trouble to rule out the wiring if you put a meter on the actuator and get someone to lock and unlock the car.
Shouldn't cost too much for a replacement actuator from a breakers yard if it turns out to be that, try Quarry Motors in Sheffield they should have one (01142755916). ;)
