Can you Quickly/Cheaply learn to weld a Z3 together? yes, you can!
IainP
PLEASE!
Do not comment on this thread until I post after more testing this weekend. Thanks.
This should be titled:
“Having no welding experience, can you buy a flux core welder and, with a bit of practice, weld inner/outer sills to a decent standard.”
But that’s a bit long.
Matt Barnes is giving it a go in his progress thread. I can weld more than a bit, I’m not an expert, or Pro, and I’ve been offering advice.
I bought a reel of flux core wire from Lidl to run test pieces, my mig can run both. A discussion with a mate at work morphed into buying the cheapest possible flux core / no gas mig welder and testing it.
£71 on eBay bought this toaster welder. Later we found the same, but different named welder for £66.
Box of 12 eggs for scale.
No readout, not even a wire speed control. The wire came well sealed, which is good, any corrosion on the wire causes chaos. Appears to have a steel liner which is also good, they last much longer than plastic liners.
0.8 or 1.0mm wheel fitted, I might try and get hold of a 0.6mm wheel and try the reel I just bought.
The earth cable wasn’t a great fit, 2 thin steel washers sorted that.
The torch is cheap, obviously, the switch is really light, I would prefer a stiffer spring. I don’t wear gauntlets, I either use tig gloves, or driver gloves, much better feel and they come in a range of sizes, gauntlets fit almost no one.
So, knowing what I’m doing, how does it weld, and how does it compare to a decent gas mig. I use a Portamig 185.
Well, first off it’s bright, tested on a piece of thick scrap I eventually settled on shade 11.5, on thin 1mm steel I went to 11.25.
I weld thin bodywork with no gap, use a technique variously called, tack and chill/zap and chill/stack-a-tack, all the same. A full penetration tack weld, immediately chilled with compressed air, or wet rag, worked across the clock. It produces minimal, if any, distortion.
Minimum setting
Immediately obvious, Very hot. straight through.
2
Heats up really quickly, straight through.
3
Much shorter tacks than gas, maybe 0.5s on, then 3sec off and I can run a line of tacks.
4
Same, that works.
5
I think little test strips heat up too much , even 3sec off and I’m burning through.
Minimal build up on the front face, it wouldn’t take much to grind flush.
Reverse side
I’m getting full penetration, I think, even on the min setting, which allegedly is 30 amps. I’m getting significant pitting, or cratering, on the back side. I need to grind the back side to see, but that will need to wait until the weekend, too noisy tonight and I only had 20 mins to test it.
I’ll run some larger pieces this weekend in 1mm steel, same as the outer sill and some 2mm, the same as the inner sill.
If you can put some clay/ceramic tiles behind the weld, you should get better result..:thumbsup:. not always possible though obviously, in that case nobody is going to see it anyway...:whistle:
Edit, sorry I did not read the first line, but it may help anyway...And I won't be offended if you get this deleted...:oops:
No worries.
Short answer to the Question: YES, you can.
Long Answer.
If you’ve never used a welder before I’d advise buying something a bit more ‘featured’. Wire speed control is a must for thin sheet.
Spend time making sure the earth connections are tight and you’re getting a Really good contact on the workpiece.
DO NOT use 0.6mm wire! You might think it’ll be easier to melt, but the arc is much fiercer, it burns through Very easily and gives a wider heat affected zone, haz. Turn it up just a fraction off min and it basically gives you a cheap plasma cutter, not a welder.
After burning through quite a few welding coupons I’d recommend 1.0mm wire, narrow haz, good penetration, consistent, less cratering and low build up.
CAVEATS:
Wear a good respirator/weld fume mask, this gives off LOTS of fume.
Spatter is impressive, keep flammables well clear, at least a meter.
Wear a cap.
Do Not try and run a bead on thin sheet, just doesn’t work.
You have to stop every 4-5 tacks and stretch them by hammering.
Tight fitment is a MUST, gaps will simply burn through.
Check youhelmet visor is clean
This is how much fume it gives off
This is 0.6, wide haz, cratering, burn through and inconsistent.
This is 1.0mm, minimum build up, good penetration, narrow haz, negligible cratering.
Here’s the problem I found. You want to overlap the tacks to form a seam weld, normally you overlap 50%, BUT, you MUST hit the metal of the tack. If you don’t the wire will hit the flux residue, which is an insulator, if it does arc it will have pushed the torch away, which then means you’re welding 15-20mm away from where you intended, like this.
All of that sandy coloured residue? It needs removed before EVERY tack. If you don’t you risk burning through, or cratering. You cannot stack more than two tacks in a row. Stop, clean, repeat, though really you want to cool it after two.
Three and a big hole.
Take you time, tack, clean, hammer, tack, clean, hammer, have everything in this picture.
Spot the spatter.
Half way along I didn’t overlap.
Tiny gap at the end and the weld pool slumpedthough that gap is less than 1mm.
If the welds don’t overlap you don’t achieve full penetration, see the red arrows.
But will it be warp factor 5?
Nope.
Obviously you need access to both sides to hammer it. You don’t have to use expensive bodywork hammers and dollies either, I used an old hammer with a polished face and a scrap piece of 10mm plate sanded smooth. For sills it’s good enough.
I’ve made multiple attempts at videos with no success, I’ll keep trying, just cos.
As ExMX5Owner says, something that acts as a heat sink helps, ceramics, copper, aluminium, all work if you have access to them.
Practice on some coupons, (small rectangles of steel), to get the machine and yourself dialled in, take your time, I can’t stress that enough, if it’s your own time it’s not costing you anything and it’s teaching you a useful skill.
In a word, or 3, practice, practice, practice.
Sort of Tony, but it’s a whole different technique to gas mig. Much trickier and less forgiving. I still haven’t figured out how to back fill holes, going to try mig/tig technique with another piece of filler wire.
As an alternative to new sills when they only need small repair, and/or small repair to the inner sills, yeah, for a complete welding newbie it’s doable with maybe half a reel of practice. £200 all in maybe, including a sheet of steel.
For a full on car restoration I would still recommend a good gas mig, faster, neater, more forgiving. 2-3 times the cost though.
Agree regards the gas Mig. It's all I used. My garage was broken into in 1992 and all my tools and Paul's tools were stolen. They were in the process of taking my Mig when they were disturbed, good thing too as the piece of kit kept us in business whilst the Insurance dragged their feet.
Nick the wife, the kids, the car if need be, but never take a mans tools, what lowlifes....I have tools handed down over generations, I would be devastated if they were stolen...
No worries.
Long Answer.
CAVEATS:
Wear a cap.
Spot the spatter.
Nope.
Another trick too, for those of us that wear glasses, and the trouble they cause worn inside a welding helmet..Is, to go and get welding magnification diopter, 1.5 or 2x, and skip the glasses.. You would be surprised how much they help, with the the right shade factor for the amperage you are using, even if you not wear glasses, as I do... I use a 2x, variable shade factor...And can whack out a pretty good weld even being half blind :oops:. It also means you do not have to get so close and soot up you visor :thumbsup:. However if you've been on a bender the night before, no amount of visual acuity will make up for the shakes... =))
I really couldn't comment. =))
But I have been practicing , and came up with this...A bit tricky but it came out pretty well I think :whistle:
