Brought a set of fog lights only realise when I got home tonight that one appears to be blown.
My question is can it be fixed or is it beyond saving
Carl
Take it backView attachment 94791 All. Need some advice.
Carl
Don’t think so, I’d take it back. I think it is a sealed unit you can change bulb and that’s it.View attachment 94791 All. Need some advice.
Carl
Doesn’t look damaged but it’s certainly seen better daysIt might not be the seal around the glass, it could well be the rear seal, take the back of and take a look to see if its damaged
OK as its alreadt wet you coukd remove the back and place the unit on a flat surface, put in just enough water to cover the inside of the glass and keep your eye on it, if the seal has gone you will see the water leak out, you can then seal that area with siliconDoesn’t look damaged but it’s certainly seen better days
Second handOr is it second ?
