I'm installing a clutch master cylinder in my 96 1.9 Z3. I've got the new one in but I have this part left over. The working conditions are so cramped that sometimes I have to work blind as there are times that you can look at what you have to do but the position needed to do the work prevents you from using your hands AND look at the work. The parts that you are working with include the clutch pedal, brake pedal, bracket that holds the 2 electrical switched or buttons that contact the clutch pedal and brake pedal and the clutch master cylinder. This piece popped off something and I can't find out where. I know sometimes you guys have exploded diagrams of systems that I don't have. There is also a stamped on the ring: G 14707. Any help is appreciated. I'm going out to reconnect the hydraulic hose back to the brake reservoir. and bleed the system in the meantime. The piece also has two sets of fingers that looks like you would squeese them together and insert them into a hole and release them so the very ends would grip to hold the piece in place. See Pics.
Thanks...Frankie
