Hello everyone
Your advice is very much appreciated.
My car is a Z3 2.8 1997 model, I have replaced the camshaft position sensor but I am still getting codes for this sensor.
Using the old sensor I have cut into the cable to do voltage checks, with the ignition on engine not running there are no voltage readings.
I have done continuity checks back to dme connector, no problems also checked all fuses.
Does anyone know what voltages I should be seeing on this sensor.
Many Thanks
Rcon101
Many Thanks
Rcon101
