I'm still thinking pump/circulation problem.
Cor Zedonist, you really are an addict!! Shopping and posting at the same time!!!Sorry Andy,
I was in tesco so only half thinking,.
hehe, my role in Tesco exactly...until we get to the beer aisle...just driving the trolley, not allowed to touch anything you see...![]()
Good morning Zeti. Its 3;07 here and I'm checking in before I go to work. FrankieThe test you made is good: it shows the valve controller it's ok.
Now it's only the rpm who plays......I still believe it's a air bleeding/ coolant level problem.
In German cars, if you have a list of possible causes for a problem, usually is the simplest one!
The suggestion to by-pass the valve was to eliminate it from list of possibles. The fact that the heater blows hot at speed as you have described indicates the valve is not at fault and IMHO that you do not have an air lock or blocked matrix (others may not agree)............ If I turn it back to hot - the air blows hot after a few seconds. This tends to lead me to think that it may not be the heater valve but if I can bypass it by disconnecting both hoses coming off it and connecting them to each other so the coolant flows uninterrupted, I assume that if the air blew hot all the time it would point to the valve whereas on the other hand if it made no difference then perhaps something else?.............
Hi,Before drawing a positive conclusion to the fact the temp changes while at speed indicating the valve is working , I would suggest the same test at idle just to verify you get the same temp differences. If the heat is at the same level as previous then the valve is working, using a thermometer to verify temps would be more accurate than simply sticking one's hand in the air flow. HTH JIM
Did you ever check the tightness of the belt driving the water Pump? FrankieHi,
With the engine warm and the car idling the temperature is only slightly warm. If I start rotating the temperature control, by the time I reach the half way mark I can definately tell a difference in temperature and by the time I have rotated it to the "cold" position - it feels noticeably cold. If I then turn it back in a clockwise direction towards the "hot" setting, at close to the half way mark I can sense a slight difference and at the hottest setting a further slight difference but far from being warm.
At the moment whenever I think about it I seem to find myself flipping between one possible cause and another. Not being very mechanically minded either I suppose I'm trying to be certain about what the cause of the issue is so that I only have to fix it once as I'll most likely have to pay a mechanic to do the work for me.
I suppose this is one of the issues that can arise where you buy a car without a maintenance history. I do have quite a few receipts but I can't see anything for "thermostat" or "water pump".
Hi - It seems ok from what I can tell.Did you ever check the tightness of the belt driving the water Pump? Frankie
