Hi and welcome from Lincolnshire, I'm running Mtec drilled and grooved with Brembo pads all round, they are pretty good
Oh you've put me right off the predator pads nowWelcome @ukcerb
As Niall said I fitted Black Diamond drilled and grooved disks with matching predator pads.
Had trouble getting the pads in as they so thick and when got them all fitted, they didn't work. No braking effect at all, frightening. But i now think it was simply because of the pads being too thick, the pistons in the calipers couldn't get enough pressure behind them, i could be wrong on this, but as the pads eventually wore thinner they worked as they should.
To be honest they don't feel any better than standard. Even on a track day they weren't great and created violent vibration through the steering after a few laps. Although i have since replace the front control arm rear bushes with poly flex which has improved the front end feel.
My opinion is I simply wouldn't bother going down the performance route for road use, they're a pain, some pads need heat in them before they'll work etc but standard pads work from cold just fine .
Steve.
Don't let it put you off mate, yes new brake fluid before new brakes were fitted and the front calipers were less than a year old.Oh you've put me right off the predator pads nowI know the black diamond disks and red stuff pads are fantastic as thats what are on the Titan (though do work much better when warm) which is the point if you drive hard, I didn't have any trouble fitting the predator pads on the Imola though?? went straight in. That's interesting Steve it will be interesting to see how they work when she is on the road. Did you do a brake fluid change when you fitted the new kit?
I'll let you know SteveDon't let it put you off mate, yes new brake fluid before new brakes were fitted and the front calipers were less than a year old.
@t-tony worked some magic on them, he put a chamfer on the pads and put some decent silicon lube on the slider pins, which improved them. They do work ok now, seem to improve as the pads wear.
I don't use the brakes hard through normal road use. Would like to try another track day now I've put poly flex bushes on the rear of the front control arms, just to see if it eliminates the awful vibration under hard braking.
Will be interesting to see how yours perform.
Welcome to the forum from Egg Harbor Township, New Jersey. Haven't done any brake work on mine yet. I think I need to get out and drive it more first..................FrankieHi all.
Just taken the plunge with a Z3 2.8 and first job is to replace the brake calipers discs and pads. Any suggestions for anything else I should do at the same time would be appreciated, brake pipes etc?
Had a look online and there is such a choice and huge price differences too.
Any suggestions as to a good setup, I don't mind cost if quality is good. Don't really want to pay just for the name.
Thanks
