Brake light test plausibility
Roadster girl
I have recently scanned my Z3 (first reg 2000. 2.8) for fault codes. Code 27 has come up and according to my Book of Codes it reads:- Brake Light Test Plausibility.
Can anyone help me to understand what this means?
Thanks to anyone out there.
Aceman
Moderator
Wakefield
///M Roadster
Hi Roadster girl and a warm welcome to the forum. :ymhug:
To answer your question I am not entirely sure but it maybe you have a fault with your brake light switch being intermittent but I am not familiar with that code number. What code reader are you using is it a generic OBD scanner you have if so it may be better to get your car scanned with a BMW specific scanner which will give more detail as to what the error is. Are you getting any other symptoms other than this code showing up, is the dashboard light on as sometimes intermittent faults don't always show up with the dash light. A BMW specific scanner will tell you if it is a pending code or a permanent logged code. Could be nothing to worry about but more information is required to make an educated guess.
What general are of the country are you in as there are always willing people on here with BMW scanners who will help a damsel in distress. :D
Edit: Just found this document which details the BMW DTC codes, it may help you but code 27 refers to an "Idle Control Valve error" but that doesn't correspond to what you report. :-\
Roadster girl
Hi Aceman
Maybe we're getting somewhere. I've done a bit of checking and the scan tool is an R5/FCX-3 made by Peake which is a code/reset tool for BMW's. They also supply the list of codes so I don't know why the codes may be different from that which a dealership comes up with. Incidentally, over the past three years since I've owned the car, the amber ABS symbol comes on occasionally but if I stop and switch everything off for 5 seconds, switch on again and drive away, within 2 or 3 seconds the light goes out until the next time.
Many thanks for all your help. If you come up with any other solutions, let me know.
I'm in far flung Argyll, Scotland. Lovely part of the country! Sun's shining today.
Aceman
Moderator
Wakefield
///M Roadster
Aah, sounds like you have got a dodgy ABS sensor then which is not uncommon and fairly easy to fix.
The Peak tools are very good but I believe they do have their own set of codes that are specific to them rather than using the OBD protocol codes that other use.
Hope you get it fixed soon so you can enjoy the forthcoming weather.
Jamezee
Peak District
Z3 2.2 sport, Z4 Coupe 3.0Si, E38 728i Oxford green and beige interior
Welcome to the forum Roadster Girl :-h
